Cannot use Esnap with View command
Can someone confirm this?Draw a rectagle and then make a view > window from bottom left to upper right corner using the endpoint snap mode to get the rectangle corners. The first corner will snap but not the second. The same problem happens if you use the Explorer View command or the Command Line version.Thanks
