Script bug
Hello !I have a problem with the script method.I try to make a extended zoom to 50 drawings.But when the script comes to the directory of the file, it doesn't accept spaces...I try to put slashes, antislashes, etc... Nothing.Examples : Script :_open"C:/Documents and Settings/BUREAU/Mes documents/BIBLIOTHEQUE/LMC/C_POI8696xxxIN_Poignée bâton D14.dwg"_zoom _eError : Impossible de trouver le dessin ""C:/Documents.DWG".Script : _openC:/Documents and Settings/BUREAU/Mes documents/BIBLIOTHEQUE/LMC/C_POI8696xxxIN_Poignée bâton D14.dwg_zoom _eError : Impossible de trouver le dessin "C:/Documents.DWG".Script : _openC:\Documents and Settings\BUREAU\Mes documents\BIBLIOTHEQUE\LMC\C_POI8696xxxIN_Poignée bâton D14.dwg_zoom _eError : Impossible de trouver le dessin "C:\Documents.DWG".And the best, it accepts the first drawing, but not the others !!!Can you help me please ?Thank you !Matt.(Sorry for my poor english...)
  • i think you can try the full path with backslashes \ and quotes:"C:\Documents and Settings\BUREAU\Mes documents\BIBLIOTHEQUE\LMC\C_POI8696xxxIN_Poignée bâton D14.dwg" _zoom _e
  • Hello Arturo Ramirez !Thank you for your answer....But your solution doesn't work... I tried it too..I don't understand.. But I think it's a BricsCAD bug.I have frgotten that I'm on bricsCAD 7...
