V8 VB API Implentation
Can someone tell me where I can find what AutoCad functions have been implemented in the latest V8 BricsCad API and which ones are still missing.Thanks,Jon
  • In the object viewer in the VBA IDE all the unimplemented methods have "NOT IMPLEMENTED" in their helpstrings.kind regards,Alexander Van HeuverzwynBricsys
  • I will try this thank you. However, as of version 8.0.16 there were print objects that were not implemented that did not say this in the VBA. Only way of knowing was when my stand alone VB application failed to run.Jon
  • Can you give an example of a method that is not implemented? I have not seen "not implemented" in the VBA IDE.
  • Do a search for PlotToDevice in the object browser.
  • I don't seem to be able to get the region.centroid to work. Is this implemented? I used it in a VBA app in V7 with success. If it is implemented, a simple routine would be appreciated.Thanks,Jerry
  • It will be available in a new V8 release scheduled for the end of this week.Best regards,Hans De BackerBricsys
