PDF to DWG converter
Is there anyone out there that can recommend a good PDF to DWG converter? I've got some pdf scale drawings of a crawler crane and would like to insert them into my drawings.
I have recently trialled progecad, an intellicad programme, and it has an excellent pdf to dwg converter. Actually about the best thing about the programme!
I've used Corel Draw to do that, by importing the PDF into Corel and then exporting the result to a DWG. Some clean-up is necessary but it's quite workable for occasional use.
Try 'PDF 2 DXF' . I use it quite a lot with a fair amount of success.
You might want to check out Visual Integrity Technologies's pdf2cad at http://www.pdf2cad.com/
