Lost commandbar
Hi guys,I seem to have misplaced my commandbar. Its nowhere to be found. Running 8.1.18 .I can rightclick the menus and turn it on or off BUT its totally gone all the time.Tried reinstalling and replacing the default.cui , no god.Any tips appreciated !Patrik
  • The position, state and size of the commandbar is stored in the registry in : HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V8\en_US\Profiles\Default\Toolbars\Commandline(if you're working with the default profile)Maybe something went wrong with these values. If you delete this value from the registry (while bricscad is closed), or start Bricscad with another profile, the commandbar should take its default position and size.
