The centralised updating in the domain.
All have done under inquiry V8. If this description to apply on the local computer and with the rights of the administrator - OK.... But: We have domain AD and 100 users with the limited rights. 1) I have written a script: Dim WshShell Set WshShell = WScript. CreateObject ("WScript. Shell") WshShell. Run "f:\BricscadPro\BricscadPro-V8.1.19.exe /s /f1"f:\BricscadPro\responsefile.iss" /f2"f:\Resultat.txt"", 2, True Wscript. Quit 2) has added it in a policy (to other working scripts). 3) at connection of the user I have received in a logfile Resultat.txt: [InstallShield Silent] Version=v7.00 File=Log File [ResponseResult] ResultCode =-3 (At usually installation ResultCode=0, as I have understood (-3) it is an error of installation because of the limited rights) From here questions: 1) Do you have any offers as it is possible to update nearby 100 workstations? 2)There is a point where serial number is specified in a file "responsefile.iss" at updating. Bricscad comes in a demo mode after updating, in cause of the removing this key. But then it turns out that it is necessary to do on 100 computers 100 files "responsefile.iss"? Or it is possible having bought to use 100 licences 1 key?
