Images (Icons)
I've read that V8 supports an Image menu that is compatible with AutoCAD. I've tried menustring $I=IMAGEMENUSECTION $I=* but it did not work. I'm using a partial menu, and have tried referencing the menu group (ie: $I=GROUP.IMAGEMENUSECTION $I=*), but neither method worked.Have also tried an "imagemenu" function from an older version of ICAD, but the V8 version stated there was an error when xloading the imagemenu.dll file.Can anyone help?
It should work compatible with AutoCAD. If you could file a support request with the .mnu or .cui file attached, we will investigate what happens and try to fix the problem as soon as possible. (Note: the imagemenu function isn't supported anymore)
Dear Mr. Clarysse, Thank you very much for responding. I changed the "IMAGE" section header to upper case, and everything now works well.
