Snapping to blocks
Most times snapping to lines within blocks before exploding is impossible. Can this be fixed?
  • This will improve if you select which snap to use (transparently) instead of relying on the running object snap (which is usually configured to multiple snap points)
  • I think you mean that it is much too slow with some blocks.We will do a big effort to improve this.regards, sanderb|n
  • No it is not much too slow or have anything to do with multiple snaps being on the same time. It simply will not snap some times. If you require a real dwg to test it on let me know your e-mail address so that I can send you one. My address is av@computersupport.itgo.com
  • email is visible next to the username on mousover(hover):)regards, sanderbricsnet
  • No, i mean statusbar. Or link properties
  • Thanks I will find I file and send it to you soon.Andreas
  • just a test of the new forum
  • This is a bit strange but try loading the blocks you cant snap to from disk (overwrite).VIOLA, they can be snapped.Dont ask me why but it works on my drawings.
