PDF export
I have looked at the PDF export and noticed a few things, maybe somebody can help.- the layernames are not sorted in the pdf, it lookes like they are exported in the same order as they are created in the drawing.- You can override the width and height but you need to restart Bricscad before you can use the new values. Bricscad reads the settings from the profile when it's start en saves them when it's closed. It would be nice if the are read from the profile (which is in the registry) when you start the export to PDF. In that way you can change the settings by lisp/vba.Thank you for any reaction.
