Vista and Bricscad Not responding
I just got a new laptop with Vista on it and I loaded Bricscad on to it. It seems to work fine for several minutes and then it stops responding. I made sure I had the latest version. and rebooted but it still does the same thing. I have not figured out yet if there is a specific thing that causes this.Any one run it this?
  • Did you already try to start bricscad by right clicking, then selecting 'Run as administrator' in the context menu? Bricscad needs to write user settings in the registry on startup, which is not allowed by default in Vista. Alternatively you can switch off the 'user account control' setting. See the Bricscad Help for more information.
  • I uninstalled, ran CCleaner and reinstalled with the latest version. and it still did it.Turned off the user account control and it still stops respsonding. Trying run as administer now.It seems to stop responding when I am working I make changes to the layer states of layers in my XREF.
