Customizing POP 0 (zero)
How can the POP0 be customized in ICAD? What if you want to put your own commands in it? Such as zoom, etcÂ&
The POP 0 menu is stored under Settings>Entity Snap. This is the section you must modify to change your middle button/Shift+right button configuration.
Great it works. But not when invoked transparantly. EG If you are in the middle of the line command and you press Shift+Right Mouse button then you only get the original menu popping up not the customized one.Can anyone confirm?
With earlier Intellicad versions, modifications to this specific section could also be invoked transparently (through the middle button). Bricsnet should reverse engineer whatever change it is they made here.
