Mline
When I type "Mline" I get the message:This command is not yet supported.Is any chance to get this command in the future?Thank you
Can I second this I have been cutting existing lines out of other files and pasting them into my drawing then editing their vertex's in the properties explorer. Bit long winded but it works!
I don't know how much interest this functionality has for most people but I was just wondering whether it is possible to write a Lisp/VBA/BRX routine that provides basic functionality. My reasoning is that it is possible to view and manipulate mline entities with the properties bar. So... would it be possible to create a new polyline say that is based on an mline already defined in a file? I regularly have to update Electrical plans which contain conduits displayed as mlines. So I don't have to create new styles just use existing ones.I am relatively competent in other programming languages so if this proposition is feasible I will take the time to learn lisp or use the BRX library. If it's not then i wont bother....ideas??
mline feature should be encourages simply because if you watch an architectural drafter on using multline to draw walls, you'll be convinced it is indeed an efficient feature.
