Properties window.
My Properties window seems to exist in a space outside of my monitors view.This makes V8 useless to me since I can not view or change any properties.I have uninstalled and reinstalled and still can't find my properties window.It there a way I can reset the location it pops up at?Thanks in advance,-Jeff HallHagerstown IN
If you start Bricscad with a new profile, or erase the following value in your registry:HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V8\en_US\Profiles\Default\Toolbars\PROPERTIESthe properties bar should take its default position. (erase the value from the registry while Bricscad is closed)
