Disappearing model entities and layouts
In model space copied entities - even though saved will later disappear and not be recoverable.In paper space - whole or partial layout will disappear after executing a print commandModel size 246KBProblem started occuring after third layout was generated.Any ideas what I should do?
  • i used to have this problem in paper space layouts once in a while with V7. i haven't had a problem since i started using v8... did you send a support request.. with the file in question...steve
  • I used to have it in V7 as well, the more vports the more unstable the file. I gave up on paperspace, sounds like it's not time to try again.
