Layer Tools
I made a few layer tools, maybe someone can give them a test :)LAYISOLAYUNISOLAYALLFRZLAYALLTHWLAYALLOFFLAYALLONLAYALLLOCKLAYALLUNLOCKLAYOFFLAYFRZLAYLOCKLAYCURhttp://caseworkcaddrawings.com/Documents/DRXLayerTools.drx
  • Hi there,I just noticed this post... a wee bit slow at times :)I just took a quick look and noticed the LAYUNISO seems to fail if a layer is removed between calling LAYISO and LAYUNISO.The LAYUNISO is a nice command to have. I have been using the isolate layer from the Bonus tools but I have to remember to save a layer state first if I want to restore.Cheers...
  • Ah Thanks for the bug report! I think I squashed it and I have uploaded it to the same link as in my earlier post. Maybe you can give this one a quick test for me, my trial version has expired, so I’m in code then pray it works mode.Dan
  • Still the same if a layer is removed between the LAYISO and LAYUNISO commands...I did not notice any obvious crash or instability but the LAYUNISO simply does nothing. Not a big deal to me though I just thought you might want to know but if your time has expired with Bricscad no worries.I really like the DRXDocTabs... Good stuff!Regards,Greg
  • Well dang, I missed a simple null test that I thought would fix the problem. Anyway if someone wants to have a look, I posted the source code over at the swamp http://www.theswamp.org/index.php?topic=23943.msg289897#msg289897I’m sure it’s something simple.Dan
  • Hi, Dan!Where can I get file od_doc_man.h?
  • This is Bricscad’s API->SDS folder
