efficad tools
How i do to run teh efficad tools, I do the download, install, but nothing.....
By default Efiicad Tools is install in the folder: Program Files/Bricsys/Bricscad/efficad tools.In this case a path to the Efficad Tools files is determined automatically.If the path differs from indicated, it is necessary to add him in Support File Search Path or change path, indicated in the file of es_et_load.lspWhat your SRCHPATH value?
