DCL and TAB code
How do I set tabs in a DCL label?When I try like this:label= "Variants \t Dimension \t Trunk Size \t For Cu System";I only get vertical black lines/bars.It is difficult to use spaces to get the headline aligned above a list_boxI use Bricscad V6.
Hi,Examble:tabs = "6 6 8 8 26";tab_truncate = true;regards Theodor
Thanks,I'll try this out.Svend
I am sorry, but it did not make any difference.Maybe it will work in a newer release of Briscad? I am using V6.Svend
