Block field shading
We use fields extensively in our title blocks in autocad to access the custom drawing properties fields.In bricscad the fields show and plot with a grey shaded background. is there any way to turn this off?Autocad has a system variable called fielddisplay that controls this. Is there an equivalent variable in bricscad?
