Save As
I have been sent *.dwg files created in Autocad 2008. When I open the file it states it is read only. I view it gight click go to properties unclick read only. Then I save as in a different file under a new name.When I go to open the save as file there is nothing in the file. Either it is empty of contains scraps of data.How do I fix this problem? Thank-You
Hard to comment without investigating one of these drawings... if you file a support request and attach a drawing we will investigate what happens and let you know what can be done.Kind regards
