Select/Unselect objects
Hi,My problem is as follows: I have selected, let's say, 5 lines. I would like to unselect one of them (4 of them are still selected). Howcan I do that?
To unselect selected entities, then press the Shift key to unselect entities. You can use any of the selection methods to remove entities from a selection set.Please see the Bricscad Help: Modifying Entities>Selecting Entities>Selection Methods to learn more about composing a selection set.
Thanku You for your reply. It is really helpful.
