explode block attributes to text
Hi,Does anyone know if it is possible to explode block attributes to text in Bricscad V8 or V9?This is a very usefull option for me in acad, but i can not find it in Bricscad.
I'd like to have that capability, too, but I don't think there's a built-in BricsCad command that can do it, at least not in v8.Jeffery P. Sanders' "Safex" command is supposed to do it, but it's not reliable in BricsCad. It converts attributes to texts, but often the resultant text contains the attribute's "Tag" instead of its "Value." I've tried to figure out what's wrong, but haven't succeeded. Maybe someone else has an idea?Safex.lsp is contained in the file "HTH2104.zip," which can be downloaded by typing "safex" as the search string at http://cadtips.cadalyst.com/?yr=2006
I have found Safex unreliable too. There are others, one is called Aexplode.lsp and might be a bit more reliable but it only does one at a time. Just google it, it's not mine but is freely available.
You can try this routine I wrote, I attached the compiled DRX modules to this thread http://www.theswamp.org/index.php?topic=24750.msg298226#msg298226
