Modify Command line background
How modify Command line background and Command line text?
If you mean the font type and size of the command line text, and the color of the text and background, you can set those in the "Display" control panel.You can open the control panel by right-clicking on the Windows desktop and selecting "Properties."Then pick the "Appearances" tab, and the item called "Window."
I think Silvio means changing the background color and font color in the command window like you can in AutoCAD. In AutoCAD, I use a black background and yellow text. I agree, the command window definitely needs work
Rewrite starts soon, scheduled to be ready end of this year/early next year.Best regards
