Shortcuts
in Other
Tried to use the key to define a new shortcut, as most of the letters are used with the combination of the key. I found that you can use the key only with combination with the numpad. Is it true ?
Indeed, you can't assign the combination Alt+letter to some custom command, because Alt+letter is preserved to access the menu by keyboard.
