initget problem
Incorrect behavior of initget function found on bricscad higher then v7 The code used is below:; do someting(initget 0 "1 2 3")(setq pt (getpoint "ENTER Point or use an Option [1/2/3]")(setq intgr (getint "ENTER an Integer");Pulldown menu is still on screen and all options are acceptable;still do something
This is by design. The design used to be different but we modified it to remain compatible with AutoCAD 2005 and later. If you insert (initget 0) the previous initget is overridden.
