V9 apply dimstyle error
I noticed hitting the apply dimstyle button brings up the explorer with no option toselect any dimensions and also when you close the explorer you get the error message"unable to recognize command please try again". I must be missing something herebecause in V7 you click the button, select the dimensions and you're done.
I already have sent a note to our developers about this matter. Meanwhile you can do the following:Choose Customize in the Tools menu, under Available Commands expand Dimensions and click the Apply Dimension Style command. Add a - (minus) before dimstyle in the command field:^c^c_-dimstyle;_applyThen it works correctly.
