V7 plotter config
In the Plotter Config box under name(s) is there any way to delete a printerthat is no longer being used?
  • The combo retrieves the printer list from Windows, and the pc3 list from actual pc3 files. If you remove a printer from windows it will no longer be availabe in the combo. If you delete the pc3 it will no longer be listed either.
