discomfort with bricscad v9 wine if really try to work
Hi all!what i want to ask...first of all it works and it is good... :)in second1. i work with keybord always(i do not use any icon on any panel)... but every time i input command that have some aditional parameters, appears "cotext' menu.. is it possible to disable it, how?2. it is personally... i have a bad habit use scrol, and if i use it with wine BC freezees for some moments... is it possible to disable it too?3. Main thing is printing.... it could not print.. it could not use print settings from system.maybe you know any suggestion to print in whatever vector... (ps, eps, pdf, pcl or other, anything)
some minor aditions1.when i press F1 the help displayed... but i did not found any way to close it.2.when i drawing something, i could not change ortho mode by pressing F8 (the sign S appears with ' above it)
