Becoming frustrated w/ V9
I am becoming frustrated with Bricscad V9. Things that worked great in V8 have trouble in V9. I'm in Bricscad limbo, I love the new features in V9 but am having difficulty dealing with the bugs. Why is this? Should we expect that there will be alot of problems everytime there is an upgrade?My latest problem: When using real time Pan with scanned images on the screen, V8 has no problem, V9 chokes. (using the same drawing).Don't get me wrong. Bricscad is the best bang for the buck around. It just seems strange that all of the bugs that I run into could be found in 2 days of a debugging process before release. The last bug I found was that the real time pan was not working (they just fixed this). The real question is, how hard is it to check such a simple common feature like this. If I were testing the program I would find this bug in the first 1/2 hour. Makes you wonder if any debugging is being done. Again,, this so far is my only major complaint,, the program is top notch, the price is top notch, the product support is also top notch!
  • Could you please file a support request and attach a drawing (and image) that illustrates the problem. This will allow us to investigate this issue, apply a correction and add an automated test to monitor this issue in future builds.Kind regards
