reactors not reacting
Hello all,It seems that the :vlr-commandWillStart event is not fired when using the grips to move entities (a polyline vertex for example).Is this a bug or I'm doing wrong (the code works with Acad lisp and lt-extender lisp) ?ThanksPhilippe
Gello, Philippe,please don't worry - your code is probably safe and OK.As you noticed, your code works in LT-Extender Lisp - and Bricscad uses the SAME Lisp engine since V8.So the reason is, that Bricscad does not send this "commandWillStart" event - Acad does send these notifications, with (pseudo) command names "GRIP_STRETCH", "GRIP_MOVE","GRIP_ROTATE", "GRIP_SCALE" and "GRIP_STRETCH".I will contact the related developers to add such command notifications for grip editing in Bricscad.Many greetings
Hello,Thanks.Another issue : entmaking a Group does not work correctly ... the group is created ok, it is selectable, but the entities inside the group don't know that they belong to a group : they don't have the (102 . "{ACAD_REACTORS") dxf codeSo it is not possible to know which group an entity belongs to by clicking this entity..Philippe
Hello, Philippe,many thanks for these hints ... do you have some little Lisp code at hand here ?Of course, I will check this issue, and probably create an internal issue/bug request then.Many greetings
My code :(defun c:gg () (defun addGroup (entList) (setq dict (cdar (dictsearch (namedobjdict) "ACAD_GROUP")) elist (append (list '(0 . "GROUP") '(102 . "{ACAD_REACTORS") (cons 330 dict) '(102 . "}") '(100 . "AcDbGroup") '(300 . "Description") '(70 . 0) '(71 . 1) ) (mapcar '(lambda (ele) (cons 340 ele)) entList) ) ) (dictadd dict "MyGroup" (entmakex elist)) ) (setq e1 (car (entsel "\nEntity 1")) e2 (car (entsel "\nEntity 2")) ) (addGroup (list e1 e2)))Now if I do :(entget e1) , I get (-1 . ) (0 . "LINE") (5 . "3C") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 256) (48 . 1.0) (284 . 0) (100 . "AcDbLine") (39 . 0.0) (10 5.97009 1.84821 0.0) (11 6.18437 3.05357 0.0) (210 0.0 0.0 1.0))but inside Acad : ((-1 . ) (0 . "LINE") (5 . "1CD") (102 . "{ACAD_REACTORS") (330 . ) (102 . "}") (330 . <Nom d'entité: 7efafcf8>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbLine") (10 1339.04 718.979 0.0) (11 1578.24 929.755 0.0) (210 0.0 0.0 1.0))There's also a problem with the DVIEW command. it doesnt work if you choose DVIEWBLOCK when prompted to select entitiesPhilippe
Hello Torsten,Do you have some news about this issues ?Philippe
Hello, Philippe,thanks for reminding me !I will try the problem today, and will keep you updated then.Many greetings
Dear Philippe,indeed, what you report is simply a bug :-(I will just create an internal task for our developer team to fix this asap.Here is a workaround for you :using (command "-group" ...) to create the group works correctly, all group member do have the reference to the group.In any case, when this issue has been fixed, I will post a message here.Many greetingsand many thanks for your help !
Hello Tortsenok, thanks. What about :vlr-commandWillStart and grips command ?Philippe
Hello, Philippe,the problem with missing command reactor(s) during grip edit has been added to our internal task list.So it should be solved in future versions.In any case, once solved, I will add a message here to know.Many greetings, Torsten
Bricscad sends a (dummy) command reactor event for "GRIP_EDIT" for any grip edit operation.So a good solution would be to add "GRIP_EDIT" to the list of commands like :(setq gripcmds (list "GRIP_EDIT" "GRIP_MOVE" ....))and inside the reactor callback check the command name against the list :(if (member cmd gripcmds) ....I hope this will help ?Many greetings, Torsten
Hello,I guess I'm missing something because I can't make it work ...I use the following code, but nothing happens when I move a polyline vertex using the grips..code: (defun command-will-start (reactor command-list) (print command-list) )(setq commandReactor (VLR-Command-Reactor nil '((:vlr-commandWillStart . command-will-start) ) ) )Can you give an example of a working code ?ThanksPhilippe
Hello, Philippe,here is my usual test code I use to verify reactors :: (defun cb (arg1 arg2) (print "--- cb ---")(print arg1)(print arg2)(print "*********")(princ))CB: (setq xxx (vlr-command-reactor nil '((:vlr-commandWillStart . cb))))#
: First line defines the callback function, the second one the the reactor - I guess you know :-)Using grip edit on a line, the following text is printed to command line by the reactor callback :"--- cb ---" # ("GRIP_EDIT") "*********" Specify new point: In case you do not get any reaction at all, then I would assume that your Bricscad version is not uptodate ... as I remember, the "GRIP_EDIT" (dummy) command was added around 2 months ago ...So you might try with latest Bricscad build ?Many greetings, Torsten 0 -
Hello,Sorry, does not work on version 9.2.15 Pro english...Any idea ?ThanksPhilippe
This is my code for command counting uses :vlr-CommandEnded. But with :vlr-commandWillStart it also works in V9.
;; ==================================================================== ;;;; ;;;; CMDCOUNT.LSP - The program is used for testing of drafting skills ;;;; of AutoCAD users. It shows the report on quantity ;;;; of the used commands and time spent for the ;;;; test drawing. ;;;; ;;;; ==================================================================== ;;;; ;;;; Command(s) to call: STARTCMDCOUNT - start command count. ;;;; ;;;; STOPCMDCOUNT - end command count and print ;;;; the report. For example: ;;;; ;;;; ====== Command Statistic ====== ;;;; ;;;; FILLET .................... 4 ;;;; GRIP_STRETCH .............. 4 ;;;; LINE ...................... 3 ;;;; CIRCLE .................... 1 ;;;; ;;;; Commands total: 12 ;;;; Time total: 0:00:49 ;;;; ;;;; ========== End Report ========= ;;;; ;;;; ==================================================================== ;;;; ;;;; THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY ;;;; MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR ;;;; PARTS OF IT ABSOLUTELY FREE. ;;;; ;;;; THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY ;;;; DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS ;;;; FOR A PARTICULAR USE. ;;;; ;;;; ==================================================================== ;;;; ;;;; V1.2, 10th Mar 2009, Riga, Latvia ;;;; © Aleksandr Smirnov (ASMI) ;;;; For AutoCAD 2000 - 2008 (isn't tested in a next versions) ;;;; ;;;; http://www.asmitools.com ;;;; ;;;; ==================================================================== ;;(defun c:StartCmdCount() (vl-load-com) (if(not cmdcount:cmdreactor) (progn (setq cmdcount:cmdreactor (vlr-Command-Reactor nil '((:vlr-CommandEnded . CmdCountReaction)) ); end vlr-Command-Reactor cmdcount:list nil cmdcount:start (getvar "DATE") ); end setq (princ "\n<<< Command Counter now started >>> ") ); end progn (princ "\n<!> Command Counter already started <!> ") ); end if (princ) ); end of c:StartCmdCount(defun c:StopCmdCount(/ cTot eTime) (if cmdcount:list (progn (setq cmdcount:list (vl-sort cmdcount:list '(lambda(a b)(>(cdr a)(cdr b)))) cTot(apply '+(mapcar 'cdr cmdcount:list)) eTime(getvar "DATE") ); end setq (princ "\n====== Command Statistic ======\n") (foreach i cmdcount:list (princ(strcat "\n "(car i)" ")) (repeat(- 26(strlen(car i)))(princ ".")) (princ " ")(princ(itoa(cdr i))) ); end foreach (princ(strcat "\n\n Commands total: "(itoa cTot))) (princ(strcat "\n Time total: " (TotalTime cmdcount:start eTime))) (princ "\n\n========== End Report =========") (textscr) (if cmdcount:cmdreactor (progn (vlr-remove cmdcount:cmdreactor) (setq cmdcount:cmdreactor nil) ); end progn ); end if ); end progn (princ "\n<!> No command history found <!> ") ); end if (princ) ); end of c:StopCmdCount(defun TotalTime(sTime eTime / r days hours minutes seconds) (setq r (* 86400 (- eTime sTime)) days(fix (/ r 86400)) r(- r(* days 86400)) hours(fix (/ r 3600)) r(- r (* hours 3600)) minutes(fix (/ r 60)) r(- r (* minutes 60)) seconds (fix r)) (strcat(rtos hours 2 0) ":" (if(> 10.0 minutes) "0" "") (rtos minutes 2 0) ":" (if(> 10.0 seconds) "0" "") (rtos seconds 2 0)) ); end TotalTime (defun CmdCountReaction(Reac Args / cLst) (if (not (setq cLst(assoc(car Args)cmdcount:list))) (setq cmdcount:list(cons(cons(car Args) 1)cmdcount:list)) (setq cmdcount:list(subst(cons(car Args)(1+(cdr cLst))) cLst cmdcount:list)) ); end if (princ) ); end of CmdCountReaction(princ "\n[Info] http:\\\\www.AsmiTools.com [Info]")(princ "\n[Info] Type STARTCMDCOUNT to command count STOPCMDCOUNT for report. [Info]")
Thanks Alexander for your help, but I still have the problem : reactors work fine, but not when using a "GRIP_EDIT" command ...I guess I need to uninstall Bricscad and redo a clean install.Philippe
Hello Philippe,I just tried the supplied code sample and it does not trigger for a grip edit in v9.2.15 but it does with the latest beta v9.3.3Hope that helps.
Hi,Thanks Greg !!! I had not tried this version 3.3, it works fine...Philippe
