Dimensioning related crash
Since the 9.1.6 version of BricsCAD, whenever a dimension is drawn from a point to an origin of another dimension the software crashes. This happens whenever a linear or aligned dimension is used and I have not tested it for other dimensions.I hope the development team makes sure this is fixed in the next update.Thanks!
There will indeed be a fix in the next update. The crash happens with associated dimensions because the snapping mechanism is used then to dimension a dimension...
We have this same problem and it's made me crazy. However I have also problem (but not only me) with support ploting paper space on ploter in version 9.1.7. I cant see any paper format on printer. One of my colege have this same problem but for others its working ok. Our IT reinstall system and Bricscad and this same problem always appers.
