Programming Tools
Hello,Has anyone tried LispGenerator ( http://www.beowolftech.com/home.html) with Bricscad yet?, Does it work?Are there any known similar tools out there for Bricscad?As Bricscad gets more and more similar to Autocad it might be a good idea to contact this companies to interest them into creating similar applications for Bricscad, very little programming should be necessary to make a program like Lisp Generator BricscadAbleBest Regards,Jose
Helo, Jose,I have tried LispGenerator ... seems to work, so far, what I have tested.Sometimes it behaves a bit strange, not sure, why ... however, if nessecary, I can investigate further.But imho, it is MUCH MUCH easier, to use some existing Lisp files, and to program the own Lisp file with a normal editor ... using existing Lisp as templates :-)
