Modifying Existing Hatch
I AutoCAD if you need to modify a previously created hatch, you can double click on the hatch, and it will bring up the hatch creation interface. Is there a similar process in BricsCAD, via command, or LISP that can be used? This is helpful when deleting boundries, or adding boundries within the hatched area.
This functionality is not yet supported, it is scheduled for the second half of 2009. Kind regards.
Thank You for the heads up.
