refedit problem
I am having problems with refedit in V9. I can select the block, start the command and view the 'nested objects dialog' as soon as I 'OK' out of it, the item i wish to edit disappearsall help appreciated
Please file a support request, attach the drawing and indicate which block our support analysts should select to reproduce the problem, we will be glad to investigate the cause and offer a solution.Kind regards.
Some times this behaviour occurs if the toggle for unique layer and symbol names is not on and the layer of the entities that "disappear" is off or frozen. Check for the toggle in the refedit dialog and/or your layer configuration.On the other hand I have had all layers appear at times (usually just prior to a crash) regardless of the state they should be in. Personally I find the refedit command unstable but that may related to the way I use it... Seems there has not been much discussion of it here.Regards,Greg
