V9 complex linetypes
Where V8 used to load complex linetypes from my .lin file, V9 just gives me an error message "Error loading (line name): Undefined line type." Anyone else having the same problem and, more importantly, any solution?
Can you please post a support request and attach this .lin file? We will investigate why it no longer loads, apply a fix, and add an automated test to cover this issue.
i'm having a problem with V9 and complex linetypes... these two for treelines do not work. i will post a support request too...steve
*TREELINE_L, Tree Line left sideA,0,-.13,[TREE,AECCLAND,s=.13],-.12*TREELINE_R, Tree Line right sideA,0,-.13,[TREE,AECCLAND,s=.13,r=180],-.120 -
These complex line type definitions refer to shape files (.shx) from which they use shapes.Probably these .shx files are in a folder that is in your V8 support path, but not (yet) in your V9 support path?Admittedly, the prompt that appears upon a failure to load a linetype is uninformative. We will improve it to provide better information why a linetype fails to load.
I think I saw the same message a while ago when I opened a drawing with linetypes having a dependency on a non-existent text style also. It was not too hard to sort out but if the messaging is improved for shape file dependencies perhaps consider text styles also.Regards.
Developing software must be like outrunning the snowball that never stops growing and picking up speed as it races downhill!
Yes, Hansmy problem was not copying my Fonts folder from V8 to V9... thanks....
