How to get 2D views of 3D model
Hi,In Bricscad if i draw a 3D model will it generate the 2D views of it automatically like in SoldWorks, IronCAD or Inventor. If yes will u please let me know how.ThanksSanjay.
Sanjay,
I know this is a very old post, and you probably got the answer elsewhere, but BricsCAD Platinum has a tool called "Quickdraw" which will generate the 2D views. My only objection to it, is it does wierd things with hidden features. For instance, what could have been represented by a dashed circle, is a series of dashed arcs. Sometimes also, it generates a dozen or more hidden lines on top of each other. I have no idea why.0 -
Hi. Is QuickDraw a bricscad command?Andrew0
Hi Andrew,yes, QuickDraw is a BricsCAD command. You will find it at the X-Solids. But as Sanjay wrote, You need the Platinum release of BricsCAD.Mustafa0
Thanks for the answerI forgot to put the "x"in front of the command nameAndrew0
