ESNAP
Hi Louis, Thanks for u'r reply as per u'r instructions i had gone through the help there is the lisp code which i have to paste in notepad and save it so that it will start as startup along with bricscad but inspite of this why don't you put up in ESNAP menu itself like EndPoint, MidPoint etc. so it becomes quite handy to use. Thanks Sanjay.
