Problems Loading and Running VBA in BricsCad Classic
I was under the impression that it was possible to run VBA code in the classic version, however,when I try to load an example program from the command line using the vbaload command I getand error message saying that the command is not yet supported.Any help would be appreciated. Thanks
My understanding is VBA is included with the Pro version.Regards.
I've installed Briscad & all goes well until I try to access it via the icon & its unresponsive. Any suggestions? I'm using Win XP.Jean
It is not possible to run VBA code in the classic version. It is possible to run VB executables and addins.
If you don't have VB installed; you can also run it from Excel or Word as these have VBA installed. You just need to register the application and all the objects will be available including intellisence to help you code. This way you can run tests on any macros or write some yourself.
