Problems with "divide" and "measure"
Hello allI'm having troubles with the "divide" and "measure" commands, here's what happens :- Draw a line at an angle of 90° and another one at 270°, also draw lines at various other angles.- Divide or measure the various lines with the "insert block" and "align with entity" options.- The result is that the blocks are perfectly aligned on all lines except one the ones at an angle of 90° (insert rotation 180°) and 270° (insert rotation 0°).Can anybody confirm this ?V 9.1.12CheersJörg
Yes I get the same. I rarely use those commands so had not noticed.You should submit a support request.
Will do that. Thank you John for your effort.
