Non rectangular viewport and its polyline
When creating a non rectangular pviewport, a polyline is created as well by Bricscad.Is there a way in VB(A) to determine, which polyline belongs to the viewport?Both are on the same layer, but so can other polylines be as well.Is there some relation I can test for?(Could not find anything in xdata)TIA,Arno van Eeuwen
Actually I'm still strugling with this one.
Does anybody know what is the connection between a non rectangular PViewport and its associated polyline?
How can the PViewport object tell me wether a viewport is rectangular or not?
TIA
Does this lisp help?
(defun c:TestVP ( / )
(if
(and
(progn (graphscr) T)
(setq result (car (entsel "Selelect viewport: ")))
(setq resultLst (entget result))
(progn (textscr) T)
(= (cdr (assoc 0 resultLst)) "VIEWPORT")
(princ "\nYes it's a viewport with entity name: \n")
(princ (cdr (assoc -1 resultLst)))
(setq clipBoundary (cdr (assoc 340 resultLst)))
(princ "\nThis viewport is clipped. Boundary data: \n")
(setq clipBoundaryLst (entget clipBoundary))
(princ clipBoundaryLst)
(princ "\nWithin this boundary data you can find this reference to the viewport: \n")
(setq clipBoundaryLstPart (cadr (member '(102 . "{ACAD_REACTORS") clipBoundaryLst)))
(princ clipBoundaryLstPart)
(princ "\nDone! ")
(princ "\nThis is not a clipped viewport ")
(princ)
)0 -
Thanks, Roy.
Actually I'm trying to achieve this through some kind of COM call in VB(A) or C#.
I'm not sure the PViewport object is exposing its clip-boundary in COM.
Currently, I'm searching for a LWPOLY at the same layer and layout as the PVIEWPORT and compare the Boundingboxes. It works but does not feel like an idiot proof method at al...l
Any other sugestions?
Hi Arno,
I do not know the answer you are seeking but I do seem to recall the polyline entity name is stored in the entity data association list with code 340... something like
(entget (cdr (assoc 340 vp_elist))) will give you the polyline with Lisp.
I also know the bounding polyline can be on a different layer from the viewport entity.
Not sure if that helps you at all... I do not know much about COM or C#
Hi Arno,
I am in the process of wrapping a few global functions for a .net project I'm working on, one of which is acdbEntGet.. it returns a list of DXF codes and values for a given object. This would certainly work for what you need. Let me know and I will compile and upload what I have.
Dan
Hi Daniel,
sounds very promising; since I'm needing it in C#.Net it would certainly help me.
Will this be part of your .Net wrapper libraries?
Cheers,
Arno
"Will this be part of your .Net wrapper libraries?"
Yes I'm adding a namespace RxNet.RxGlobal to house global functions
that are frequently p/invoked. Some of them may duplicate methods accessible
via com.. but oh well, the more the merrier : )
Just curious, are you using the libraries?
Daniel
Hi Arno,
I have uploaded the .net wrappers (1.0.0.4) to the developers area. See if this sample gets you started.
[CommandMethod("vptest")]
public static void vptest()
{AcadApplication application =
Application.AcadApplication as AcadApplication;
if (application == null)
throw new System.Exception("Could Not Get Application");
AcadDocument Doc = application.ActiveDocument;
try{foreach (AcadEntity e in Doc.ActiveLayout.Block)
{if (e.EntityName.Equals("AcDbViewport"))
{ResultBuffer buf =
GlobalFunctions.EntGet(new ObjectId(e.ObjectID));
int index = buf.FindIndex(Has340);
if (index != -1)
{ObjectId VPid = new ObjectId(e.ObjectID);
ObjectId Entid = (ObjectId)buf[index].Value;
Doc.Utility.Prompt(
String.Format
("\nViewPort Id: {0}, Polyline Id: {1}", VPid, Entid));
//AcadEntity ent =// Doc.database.ObjectIdToObject(Entid.OldId) as AcadEntity;}
catch (System.Exception ex)
{System.Windows.Forms.MessageBox.Show
(String.Format
(":{0},\n:{1}", ex.Message, ex.StackTrace));
internal static bool Has340(TypedValue val)
{return val.TypeCode == 340;
Thanks Daniel.
I picked up your stuff and see I have to upgrade my 2005 Express to 2008.
Your example looks cristal clear, I expect it to work as fluent as your .Net wrappers and the TAB tools I picked up from the Swamp earlier this year.
I've have had a go on the .Net wrappers and they work like charm.
I'll get back to you.
Arno
Still having fun @ the Bund?
To use the wrappers, you only need VS2005 or .NET 2.0, I do recommend using VS2008 (what I used for the sample) to take advantage of the new features, such as extension methods
Oh the bund is a real nightmare for the tourists, the whole walkway in front is being rebuilt for the Expo, If you plan to visit before 2010, bring your hardhat : )
Hi Daniel,
After initial struggle with RxNet 10.0.0.4 (Cannot load in V9.3.13 Pro) I found your updated 10.0.0.5 version.
Loads ok in V9.3.13 and the example works ok , I get two Id's returned from an irregular vieport, so I can take it from there.
Cool stuff!!
Thanks,
Arno
For those interested, here's the little extention I made on Daniels example.
After obtaining the Id of the polyline object, it only takes a few steps to get to the actual polyline object and its coordinates.
AcadApplication application = Application.AcadApplication as AcadApplication;
throw new System.Exception("Could not get application");
try
ResultBuffer buf = GlobalFunctions.EntGet(new ObjectId(e.ObjectID));
if (index != -1)
ObjectId ENTid = (ObjectId)buf[index].Value;
Doc.Utility.Prompt(String.Format("\nViewport Id: {0}, Polyline Id: {1}", VPid, ENTid));
AcadLWPolyline lwPoly = (AcadLWPolyline)Doc.database.ObjectIdToObject((int)ENTid);
double[] coords = (double[])lwPoly.Coordinates;
for (int i = 0; i < coords.Length / 2; i ++)
Doc.Utility.Prompt(String.Format("\nViewport X: {0}, Viewport Y: {1}", coords[i * 2], coords[i * 2 + 1]));
else
//Doc.Utility.Prompt(String.Format("\nNo Polyline found for entity {0}", e.EntityName));
System.Windows.Forms.MessageBox.Show(String.Format(":{0},\n:{1}", ex.Message, ex.StackTrace));
}0 -
Nice work Arno!
Not sure if this will help in your situation, ... I have added the function GetCurViewportObjectId, that will get the ObjectId of the current active ViewPort
ObjectId vpid = GlobalFunctions.GetCurViewportObjectId();
Daniel
