Properties window position
Hello,I managed to move my Properties window completely off the desktop - i.e. it is not visible when I issue the Properties command so I cannot move it by dragging with the mouse. Is there another way I can dock it or otherwise bring it back into view?Thanks,Phil
  • You could start Bricscad with another profile, or edit your registry at the key :HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V9\en_US\Profiles{the name of your profile}\ToolbarsValue: PROPERTIES. Delete it or modify the coordinates.We will improve the properties bar's positioning code so that it detects that it is off the screen and if so, jumps back to a default position.
