raster image problems
When i insert a raster image into a drawing it will show up fine. As soon as i close and reopen the drawing i lose the image. The frame box is still their and if i go into image management the image is still their and loaded. I end up having to unload and reload everytime i open a drawing with a raster image. Any help would be great. I really don't want to have to tape all these e&s details to my page. (again)
  • Check the path to the file if you use different machines.It has to be the same from all machines.Happends to us sometimes.PATRIK
  • If the problem persists, please file a support request, mention the Bricscad version number you are using, and attach a sample drawing and raster file. We will be glad to investigate the cause of the problem.Kind regards.
