ACAD commands and icons
I have following problem and hope you can give me some help:As i'm used to the Autocad interface I tried loading the autocad.cui file in Bricscad, and so far it worked. But there are several commands and icons from autocad which Bricscad does not recognize (e.g. the "quick dimension" "qdim" command)I would like to know if there is a way to get those icons and especially the commands implemented in Bricscad, so I can really use Bricscad like Autocad.Thanks in advance
