Properties bar - layer
When I select an object in properties bar I see name of the layer on with is this object. But when I try pull down list of layers this list start from a first position - not from this layer name. How can I customize BricsCAD to start in this place.Interesting is then when I pull down and press a arrow - list show a current place, and next when is select object on layer near tu first - list start with correct position.
