import custom v6 aliases, shortcuts etc. into v9
Hello,we've just upgraded from v6 to v9. Before upgrading i've saved my custom aliases (.ica), toolbars (.mnu) and keyboard shortcuts (*.ick).How can i import them into v9? I didn't found a way nor some hints in the help files or internet.Thanks
- toolbars (.mnu): these can be imported in v9 using MENULOAD or CUSTOMIZE dialogbox - "Browse" amd "Load" from the Menuload dialog, or "Load partial CUI file" from the Customize dialog's File menu - just select filetype "MNU" in the Open File dialog. The mnu file will be silently converted to the new CUI format.- aliases (.ica): v9 can read ICM files (pulldown menus) but no ICA or ICK. The aliases can be moved to v9 by exporting them as PGP, instead of ICA, in v6. The resulting file should be called "default.pgp" and placed in the current "support" folder (next to "default.cui")- keyboard shortcuts (*.ick): cannot be imported in v9, currently. I guess the best way of moving them into v9, is entering them one by one manually, in the CUSTOMIZE dialogbox, if there are not too many..
It works fine, tyvm!A suggestion for next version:Predefined flyouts for circle, arc etc. would be nice. It takes a lot of time to append the tools one by one to the flyout or at least allow multi-selection in the customize dialog.
Hello again,
we got v10 now and a terminal-server-solution running on Windows Server 2008 ("Vista Server").
I can replace the default with my custom aliases (...\user\appdata\...\support\...). It works fine. But after reconnect to the server all aliases has been reset to default.
My Autorun-batch to copy the stuff back works, but it is only a quick-and-dirty-solution. Does some1 have a better idea?
