add symbol & remove "command window"
Dear All...1. I want to add symbol such as diameter, plus, minus, degre, etc to a linier dimension text, How ?2. How to setting so then when I pick a command like rectangle, a window not appear.Please refer to this image :http://www.4shared.com/file/84711514/f634f40d/bc1.htmlThanks
This is behaviour in other 2D cad application :http://www.4shared.com/file/84725661/39bc59b/ac1.html
The display of the prompt menu is controlled through the PromptMenu variable. Choose SETTINGS in the SETTINGS menu, then type 'prompt menu' (without the quotes) in the search field. Choose 'Don't display prompt menu' to suppress the prompt menus.To add symbols and additional text in the dimension text, use the Suffix and Prefix setting in the dimension style, if the symbols and/or text are needed in each dimension entity. To edit the text of a single entity, select the entity, then select TEXT OVERRIDE in the PROPERTIES BAR.%%p adds plus/minus, %%d adds the degree symbol, %%c adds the diameter symbol, <> adds the default dimension text.
Dear Louis,Thanks for your explanation....Thats very helpful...BTW, how about my question about wblock ?
