Fatal Error During Trim Command
It seems I have a continued Fatal error when using the trim command, either as a keyed shortcut or direct from the tool bar. I can't reproduce/force this error with any consistency. Has anyone else come across this problem? Has anyone been able to reproduce it in order to post a SR. Marc
I have no problems with Trim.Is it possible one or more lines are not at the same Z Elevation? Not that that should necessarily cause trouble.
I also have no problem with TRIM.Note: I run with PROJMODE set to 1 (project to XY plane).
The UCS is set correctly, and PROJMODE is set to 1. I will try and trap what happens in the prompt history.
Marc,Bricscad has been dropping crash_report.txt files for some of the crashes I've experienced. I find them in the directory where I started Bricscad or the drawing directory. I've been sending them in attached to a service request when I find them. I've found them in sizes from a few KB to more than 100MB.If your problem is creating these files it may help the support people.Regards.
Marc,chances are that this problem is related to the nature of the entities contained in the drawings you are processing. Could you file a support request and attach one or more drawings so we can have a look and try to reproduce the problem? And if you'ld happen to find a crash_report.txt file that would indeed be helpful too.
Greg- Thanks. I will look for those.Hans- I will file a SR as soon as I can either find the file Greg mentioned, or get it to repeat. Thanks for the help.
