Mesh To Solid for Bricscad
Today SYCODE released Mesh To Solid for Bricscad.Mesh To Solid for Bricscad is a plug-in for Bricscad which gives Bricscad the ability to convert a mesh to a 3D solid.General solid modeling software, such as Bricscad, does not have methods to manipulate or modify mesh objects. Solid modeling operations such as boolean operations (union, subtraction, intersection), extrusion, offset, taper, shell, etc. are possible only with solid or surface objects. Moreover, there is no way to convert a mesh into a solid so that the solid modeling operations can be carried out on it. Mesh To Solid for Bricscad solves this problem by giving Bricscad the ability to convert a mesh to a 3D solid.Meshes in Bricscad are of two types: PolyFace Mesh and Polygon Mesh. Mesh To Solid for Bricscad can create a solid from both these types of meshes.To download a 10 day/run trial please visit http://www.sycode.com/products/mesh_to_solid_bc/index.htmDeelip Menezes
