Entity snap
Is there a BricCAD (v9) equivalent to the AutoCAD 'F3' in order to quickly turn entity snaps on and off
  • Clicking the "ESNAP" button on the status bar at the bottom of the screen toggles osnaps on and off. If it's not there, click on the pull-down icon at the end of the status bar and select OSnap.
  • Errrr, sounds like I'm missing something: the default 'out-of-the-box' behavior of Bricscad is that F3 is exactly doing that: toggling entity snap on/off. If it isn't, check Tools...Configure...Keyboard...F3: the command linked to it should be '_-osnap;_t
