Search-Function in this forum
Hi,
is there a possibility to search this forum also by way of google?
or do I HAVE to use the search-field here in the forum directly?
Thanks, Stephan
Thanks for the reply, Ignace!
What I don't like is the fact that with site:bricsys.com I get other results also (not forum only).
I therefore tried site:bricsys.com/common/support but with that approach the result is missing out on many forum-threads altogether.
So I guess your suggestion IS the best available solution, although not optimal.
Thanks.
0 -
Try to include
Forums > Bricscad
like this:
http://www.google.com/search?q=Forums+>+Bricscad+site:bricsys.com
0 -
Thank you Gerrit!
This is an excellent Idea! I made it even better in putting your suggested phrase into double quotes ("). This way even the beginning of the title is basically always shown in the results, giving me a better overview, what each search-result is about.
Thanks to both of you, guys for the good team-work.
0
