Automatic numbering-routine in blocks
Hi
I am looking for a function within BricsCad or Lisp-routine, that can automate roomnumbering.
I have 22 floors in a 3 buildings with 25 rooms on each floor --> 500 room numbers. The rooms are identical, I have made a block for this, and now I would like to give them a number without doing it manualy...
The roomnumbers go as example:
231,232,233 on the second floor,
331,332,333 on the third floor and so on.
Any Ideas? I have earlier use Attributes in blocks, but as far as I know you have to specify the number at each insertion.
Best regards,
Mads Boserup Lauritsen
